Fri Aug 07 2015
Leica CM1900 Service
Good day,
I have a question about Leica CM1900. I need to delete the service icon (on Display). Can anyone tell me the key combination?
Greetings
Thu Aug 13 2015Reply from Paul Firnschild
Do you still need help with this?
If so, push both the "key" symbol button and the + (specimen temp increase) for at least 5 seconds.  That should clear it.  If not, I also have a more involved method from the manual.
Fri Aug 21 2015Reply from TMed
Hello mr. Firmschild,
Can you send me the service manual of the CM1950?
(Not the user manual)
Greetings
Fri Aug 21 2015Reply from Paul Firnschild
Hello Tmed,
I could scan it in and email it to you.  What is your regular email address?  Just curious though, what is your company and where are you located?
Paul
Fri Aug 21 2015Reply from MedWrenchManager
MedWrenchManager
The service manual can be found under the documents tab, here.
Mon Aug 24 2015Reply from TMed
Hello Paul,
Im from Germany and i am a mechanic.
I repair these Kind of devices.
My e-mail adress is
kevin-henke@web.de
Greetings
Tue Aug 25 2015Reply from TMed
Hello Paul,
I cant answer your e-Mail
You have to press the defrost Button the arrow down Button and the key Button.
Then there is a Service menu.
With the arrow button you can Switch to this menu.
When on Display appear runtime press defrost Button and After That press refresh button.
The cryostat restarts.
I hope i can help.
Greetings
Tue Aug 25 2015Reply from Paul Firnschild
Thanks TMed!  Since a CM1950 manual has been linked above, I assume you no longer need one.  Correct?  Let me know if I can help you with anything else.
