Wed Jan 11 2012
Baxter 6201 constantly beeping
I found the battery fried. Replaced it and tried getting in configuration but it won't quit beeping and I can't get in configuration. Any suggestions?
   RE: Infusion Pump Report Post
Wed Jan 11 2012Reply from Dean
Dean
There is an internal clock/ROM battery, also. I have fixed this issue in the past by replacing that battery, but it only works about half the time. If replacing the internal battery doesn't fix it, it's usually a sign that the main board is fried.
Dean Stephens EET, CBET, CRES
(Not my first rodeo...)
Wed Jan 11 2012Reply from tjgdjn
I removed that battery and tested it. It is reading 3.069v. I guess it is their board. Thanks for the advise.
Wed May 30 2012Reply from mouser69
there is a battery fuse on the harness this could also be the issue
Wed Oct 29 2014Reply from brodak
I had this problem on a 6301 and it was the 1 amp fuse (F302) on the main board.
