After system start up there are two popup boxes located at the top of the machines checkout screen that say "Set Alt O2 Flow! Check Agent Setting!".
Other machines do not display this message and this only happens when first powered up. If you restart the machine this message does not re-appear.
Could this be aproblem with the Alt O2 switch, mixer, transducer issue or something else?
* Machine has version 8.01 software
