I need to clear patients from the hard drive
Deleting patients from HDD
You can delete studies in the patient browser. If you are talking about deleting and recreating the database here are the steps.
-Go into service (click menu button, then click maintenance, ctrl+shft+next will open service log in screen)
-commad line
-type in "stopz.js" execute
-application will shut down after a few min. and you will be at a windows desktop
-click start and open setup menu
-a service menu is displayed go to uncommon tools
-click remove database(all exams will be deleted it will take several min.)
-click create database (will also take several min)
-you can clean exchagne board database if you want not neccessary
-click start and reboot system.
-should be able to put test patient in and capture images. IF you get an error may have to repeat again.
