Has anyone out there had an issue with the HV Tank leaking oil? Unit is only 3 months out of warranty and all of a sudden the HV Tank has srung a leak. G.E. says it's going to be a $10k repair cost. Sounds to me like this may be worthy of a recall but have found nothing of the sort. Thoughts?
Thu Jan 07 2016
High Voltage Tank Leaking
Thu Jan 07 2016Reply from SFS1
One of our Optimas started HV tank leaking shortly after warranty. Did cost around 10K for tank and aux box replacement. Leak is a known problem. GE knew it when I was at Optima training.
Fri May 19 2017Reply from Walter Cahill
I have also just recently discovered a leaky tank. Good to know I'm not the only one. About half a year out of warranty.
