How do I change the IP address?
Do I need the software to make this change. I need to change the IP in both the reader unit and the CL. Alos, does anyone have a copy of the Service manual I could get?
Is simple
1-turn off the cr
2- press the 1 and 4 button at same time ( while the cr turns on)
3-seek in the menu the iP address of cr and console (server)
4-change the address
I tried this on my machine and it didn't work for me. It is a 2012 machine running version 3.2.
Is there something more to it than holding 1 and 4. When should I press them before turning it on or after turning it on?
Dan
If I hold down 1 and 3 then that seems to work.
Although the strange thing is the IP address it shows which isn't the one I current use to connect or Ping to the machine. Is there more to this than just that setting?
Dan
