Mon Mar 07 2016
password multix pro
Hello, I need the password to schedule a pro multix room. The problem is I have to enter data and select other settings, prompts for a password and do not know. A greeting.
Tue Mar 08 2016Reply from John D
John D
PW is Multix - you will know if its correct or correctly entered when the "ok" button turns black and allows you to enter it.
John DiPasquale
www.technicalprospects.com
+1 (920) 757-6583
Tue Mar 08 2016Reply from quino
I do not explained well. After entering service, the option data, with software version VC00F have the option "other" this is the password I do not know. Greetings and thanks for answering.
Wed Mar 09 2016Reply from John D
John D
AS I understand it that area of the software is for Siemens only.
John DiPasquale
+1 (920) 757-6583
Wed Mar 09 2016Reply from Ralph Frizzle
Ralph Frizzle
should    multix  be all lower case???
Ralph Frizzle
Radiology Engineer
Ralph@GermanElectronics.com
John D
Multix - case sensitive
John DiPasquale
+1 (920) 757-6583
