Hi
I tried to re-install software on a GE Logiq 5. After installing base system and software on boot up i get a message "SW LICENCE" on the bottom left hand corner. I tried to type in the HW number i had written down prior to software installation, but a message appears indicating invalid licence.
What could be the problem?
Regards,
Paulo Ferreira
Thu Mar 01 2012
GE Logiq 5 SW Licence error
Thu Mar 01 2012Reply from CCMS, Inc.
Hello Paulo,
Does the system fully boot to the home screen with a probe running?
If the system does not boot fully to the home screen and stops asking for the SW/HW License, odds are the wrong version of software was installed, the option hardware key is not installed on the parallel port or there is a hardware issue with the parallel port.
Regards,
Chris
C&C Medical Solutions, Inc.
_____________________
Christopher Turner
Phone: 317-804-8099 x103
Fax: 317-804-8099
Yahoo IM: caruso122
Skype IM: cturner122
Fri Mar 02 2012Reply from fanies
Hi Chris,
Thank you for your support.
The problem was the dongle was loose probably due to transportation.
Regards,
Paulo
Fri Mar 02 2012Reply from CCMS, Inc.
You're quite welcome!
Christopher Turner
Fax: 317-804-8099
Yahoo IM: caruso122
Tue Aug 15 2017Reply from umeshkirant
Dear Paulo,
Do you happen to have the application software for GE Logiq 5 Pro? If you do have could you send it to me on umesh.kirant@norvichospital.com?
Best Regards,
Umesh Kirant
Wed May 08 2024Reply from TECNOMEDICS
Buenas noches, estoy interesado en su software logiq P5 con extensión .tib, puede usarlo a través de acronis o en formato .iso.
