Mon Mar 12 2012
trackball-GE Ultrasound - LogiQ9
Does anyone have any procedure for replacing the trackball on the LogiQ9?
I have a bad one and the unit is just out of warranty. I can't find any information about this repair! Any help will be appreciated!
Wed Mar 14 2012Reply from dferguson
Wed Mar 14 2012Reply from rsiefers
I checked there, no luck
service manual doesn't show trackball replacement
thanks anyway!
dferguson
If you are unable to find a full removal and replacement procedure, then check for the procedure for the next higher assembly (i.e. lower control panel).  After that there are only two screws and two cables to remove and/or replace.
Mon Apr 09 2012Reply from Radiology OneSource
Radiology OneSource
Which BT0 system do you have?
Debbie Cole
Radiology OneSource Inc.
Wed May 02 2012Reply from rgashi
remove touch panel with 4 screws through back, remove ALL screws under the lower user interface/control panel. now you'll see the trackball under neath the lower user panel two screws and it comes off.
