I have smartlyte analyzer that is running for period of two months but now it gives me on the screen"inspect reference housing. I followed all the possibilities for maintenance in the "operators manual” such as- check for proper filling of the reference housing- ensure that the reference tubing is securely connected to the receptacle- since this test utilize standard A. make sure that it is aspirated properly into the measuring chamber. if not replace the ise pack- clean the reference housing- please I want a solution to my problem. thank you very much
Sun Aug 14 2016
re: smartlyte electrolyte analyzer
Tue Aug 16 2016Reply from Brunno
I'm Brunno with Diamond Diagnostics. Please call our productsupport line @ 508-429-0450 ext. 337. They will help you through this problem.
If you need further assistance and would like to call me direct you can use extension 340.
Best,
Brunno
