Fri Sep 23 2016
Calibration Procedure
Is there a calibration for this JM-103 if the tests are outside of the stated values with their tolerances?
Sun Oct 30 2016Reply from Arun
Even I have issue with the values of JM103. Do you got any solutin for your issue?? do you have any manual of the same????
Mon Oct 31 2016Reply from GBlair
I have a slightly better manual than the brochure. I'll have them post it here.
Mon Oct 31 2016Reply from MedWrench MM
MedWrench MM
Hi GBlair,
Please send the manual to jpayne@medwrench.com and I will add it to the product page for all MedWrench users.
Thank you!
Jonathan F. Payne,
Media Manager @ MedWrench,
866-989-7057,
Jpayne@MedWrench.com
MedWrench MM
Thanks to GBlair I have added the Instruction Manual to the product page. You can find it listed under the documents tab.
Jonathan F. Payne,
866-989-7057,
Mon Oct 31 2016Reply from Arun
Thank you for the support. That really helped me.
Fri Feb 10 2017Reply from jaydoneit
If I calibrate it from the unit I am out of calibration, if I use pure white paper as a base it is exactly right on the money. Any suggestions?
Wed Sep 05 2018Reply from RenatoM
hello, has anyone calibrated the Konica Minolta JM103?
Thank You
