Mon Mar 26 2012
Calibrating Power Supply
How do you  Calibrate the Harmony LED power supply.
   RE: Surgical Light Report Post
Wed Apr 11 2012Reply from GaryBiomed
GaryBiomed
You should contact steris, they're pretty good at helping you out
http://www.steris.com/contact/
Service Support
Phone: 800.333.8828
Tue Dec 17 2024Reply from MedTechNick
Did you ever get help calibrating the Harmony LED power supply?
Tue Dec 17 2024Reply from Chris-CBET
Chris-CBET
If you know the voltage, you can calibrate by removing the wall panel cover. Check your voltage at the square 4 pin connector on the bottom left. There is a small round hole towards the right side of the front of the power supply, about an inch above the bottom of the plate. That is the access to your potentiometer.
I made a video not too long ago
https://youtu.be/iLACHM3ucg4?si=b39WEpzYboa3ej5o
