Hi all,
This is regarding a Voluson P8 issue. The problem is the machine will work fine with some set of linear and Convex probes. If I used another linear or convex probes, it will not work. Probe switching happens, but scan area is not coming instead we can see the back ground. If I use linear probe in the first port, I can hear relay sound ticking continuously. All of the probes which I used are 100% working. I checked in other machines too. I restored the software, reloaded the software in new hard disk, but no use. Please help. Thank you
Fri Oct 28 2016
GE Voluson P8 Ultrasound machine
Fri Oct 28 2016Reply from MedWrench MM
If you are in need of immediate assistance please feel free to reach out directly to our Ultrasound System sponsors. They are always happy to help out when they can.
Jonathan F. Payne,
Media Manager @ MedWrench,
866-989-7057,
Jpayne@MedWrench.com
