Does anyone else have problems with short life cycle batteries in these units? While I understand user behavior can impact battery life, I Seem to average 6 months or less on the 12V battery. I have seen this over the 5 units I am responsible for. Is there a better brand of battery that is lasting for others, or different specs. The battey I am changing this evening lasted 2 months....
ELI 350 battery short life?
Dear Jim,
Please let me know what is your zip code and contact information and I can have someone from Mortara reach out to you.
Regards
Nayeem
Was there a solution to the reported problem above? I am experiencing the same issue with my 2 units, but am lucky to get 6 months out of them. I talked to tech support, they said that most likely the problem is that the end user is using the unit until the battery is dead which causes the battery to not charge as well each subsequet time until there is nothing to charge.
I'm having the same problem with my 6 ELI 350.
I keep changing the batteries every 2 to 6 months. We did try many different kind of batteries and it's always the same problem.
If you put a new battery and mesure it's voltage, you'll see it dropping real fast (while only using the screen. Not the printer)
