Fri Mar 30 2012
aspen not powering up
I have an aspen that is not powering up.   All that indicates on the LED is the "."  .   I did get an error once "4" .   The unit will initiate power up for about  a second then drop completely dead.  Is there a service manual available?
Fri Mar 30 2012Reply from dferguson
dferguson
System shuts with an Error Code "4" displayed (i.e., Main Power Supply CODC over voltage); therefore, one of the DC outputs of the Main Power Supply is over-voltage. Try unplugging J8, J7A, J7B, and J14, one at a time to isolate the problem.
