I need manual service for MUX 100H mobile art,,
can you send to my email, please
thank for your help me
Both of these errors are due to bad batteries. F52 is the battery voltage during charging is less then 100VDC. F56 is the negative battery pack is 12vdc higher then that positive pack. I would replace the batteries. You dont have to buy shimadzu batteries. We use to use batteries that were in UPS systems. 12V 9AH F2 connector.
Tengo un error F56 que aparece después de haber reemplazado las baterías, ¿el error puede deberse a que una de las baterías vino defectuosa de fábrica?
