Wed Dec 07 2016
1105 stretcher deck will not lay flat
Thu Dec 08 2016Reply from MedWrench MM
What equipment are you specifically referring to? Manufacturer/Model?
Jonathan F. Payne,
Media Manager @ MedWrench,
866-989-7057,
Jpayne@MedWrench.com
Thu Dec 08 2016Reply from BPeardon
Fri Dec 09 2016Reply from MedWrench MM
If you are in need of immediate assistance please reach out directly to our Stretcher sponsors. They are happy to help.
Jonathan F. Payne,
866-989-7057,
Fri Dec 09 2016Reply from Stryker Tech
Fri Dec 09 2016Reply from Ray Brown, CBET
Or just adjusting the gas shock? A lot of times, the jam nut gets loose and it will do just that. The nut needs to go tight up against the reservoir body, then the adapter to release the button up tight against the jam nut (and then jam the nut against the adapter to lock it in place), then bend the adapter lever to work when only one D-ring is pulled.
