Self test pass
Goes into Biomed failure.
How to reset or repair
Primary Audible alarm Post.
Self test pass
This is what the manual says about your System Failure Alarm "Primary Audible alarm Post".
Power-up self-test sensed no current flowing in the primary speaker. Speaker may be unplugged or wire came loose from connector. Check connections from main board to interconnect and from interconnect board to speaker. Replace speaker if wiring is intact.
Let me know if you need further help.
Hasen
(855) 477-8866
If you are in need of immediate assistance please feel free to reach out directly to our Infusion Pump sponsors. They are happy to help.
Usually one of the capacitors on the IC board is faulty--often see a loose connection & sometimes it breaks off altogether. Hope this helps.
