Can anyone tell me the possible causes of above mentioned error in mindray bs400?
Tue Dec 27 2016
10PSI out of range
Fri Feb 16 2018Reply from JESUS1981
A1018 12
10psig
pressure is
abnormal
Air pump/valve
abnormal. High
pressure protection of
pressure switch
started. Protection
valve abnormal.
Container leakage.
Oil
separator/one-way
valve clogged.
Connector leakage.
Precision regulation
valve abnormal
Identify failed part.
Check if 10psig is
normal by reading
pressure gauge on
hydropneumatic
assembly panel
Greettings from venezuela friend
