Mon Jan 16 2017
DHCP or Static i.p.
Hello,  Our BV Pulseras are running version R2.2.6.  Our IT department has asked that we switch to DHCP if possible but I see no option for this in the BVSCOPE network configuration.  Any guidance would be appreciated.
Fri Jan 20 2017Reply from Bill McSharry
Bill McSharry
I don't know if this unit can be set to DHCP, but I would not do it if possible.
At some point your network will not supply the unit with a DHCP address because it is all out of them, or the DHCP server is not working.
And then you will be chasing ghosts.  The tech will complain that they can't download to PACS, and 3 out of 4 times you go to look at the problem it will work fine.
Wed Feb 08 2017Reply from www.PI.solutions
www.PI.solutions
These systems are static IPC only.
Jamison Ashby, MBA
Owner: Precision Imaging solutions
www.PI.solutions
www.PI.solutions
Static IP.
Jamison Ashby, MBA
www.PI.solutions
