Sat Jan 21 2017
how to change the date of Toshiba Xario XG
hello
i've 2 problems with myToshiba Xario XG :
*I can't set the date of my toshiba xario XG in 2017 year , it is on 2002
*since 2 weeks , when I switch on my Toshiba Xario XG , after 2 or 3  secondes it stop , than after 1 or 2 minutes  it restart spontaneousely (like restarting or rebooting).
the first time when this problem is appear , the machine (Toshiba Xario Xg ) changed the date, it past from 2017 to 2002
please help me
Tue Oct 03 2017Reply from montykenedy
I have problem with maintenance prompt in Toshiba XARIO XG.
If  you could help solve this problem, Please mail me.         martin.samed@wp.pl
Thanks in advance
Best regards,
I have problem with "maintenance prompt" in Toshiba XARIO XG.
Thanks in advance
Best regards,
Sat Jun 10 2017Reply from shahzaibkhan
anyone have any problum also contect me i have software also username pasward and key
        khanmedicallink@gmail.com
yes i can help contect me
Sun Feb 05 2017Reply from yamek
hi, I changed the battery on the cpu, but I can't change the date . I taped the current log and password you sent me,and when I click on OK it appear this message: SAM:LM:system clock has been set back. please help me to change the date of my toshiba Xario XG
Wed Jan 25 2017Reply from BMET-KY
Dave and Yamek check your e-mail. Dave I sent it to you on the 17th if you didn't get repost and I will call you
Wed Jan 25 2017Reply from dferguson
yamek
Does anyone have the current service login information?
Dave Ferguson>
Medical Equipment Technician
Conquest Imaging
Ultrasound Parts, Probes, Service, Training and 24/7 Technical Support
http://www.conquestimaging.com/
Toll Free: 1-866-900-9404
Mon Jan 23 2017Reply from yamek
hi,please I need the password thank you e-mail : mekamene2007@yahoo.fr
Mon Jan 23 2017Reply from BMET-KY
I agree with JohnW repalce the CMOS battery. As far as changing the time. You have to log in to service for that. pull up the menu then select maintenace at the bottom. hit ctrl+alt+"next"(near trackball). Type in the current log in and password. then select command line towards center of screen. you can type in control panel in the box towards the top and hit go. Then select date and time. If you need the current pasword post you e-mail.
Sat Jan 21 2017Reply from Danelis
Replace the battery on the cpu pcb
