Hi , i would like to reset the maintenance wrench on crystat CM1950 and also the ip adress to service the cryostat CM1950 .I also have an error E0 39 ( i replace the box compressor temp sensor but the error keep coming).
THANKS
vbellingen@yahoo.fr
Wed Feb 01 2017
reset the maintenance wrench on crystat CM1950 / ip adress to service the cryostat / ERROR E039
Fri Feb 03 2017Reply from IPNDave
Fri Feb 03 2017Reply from Paul Moyer
You can try this procedure ;
"Push both the "key" symbol button and the + (specimen temp increase) for at least 5 seconds. That should clear it. If not, I also have a more involved method from the manual."
"You have to press the defrost Button the arrow down Button and the key Button.
Then there is a Service menu.
With the arrow button you can switch to this menu.
When on Display appear runtime press defrosts Button and After That press refresh button.
The cryostat restarts."
Reply back if this works.
Thanks
Paul
Fri Mar 17 2017Reply from paul van bellingen
