Hello! One of my technicians accidentally poured a small amount of Isoflurane INTO my sevoflurane vaporizer. Is there anything that I can do in house to alleviate this?
Fri Feb 17 2017
Isoflurane in isoflurane vaporizer
Fri Feb 17 2017Reply from MedWrench MM
What equipment are you specifically referring to? Manufacturer/Model?
Jonathan F. Payne,
Media Manager @ MedWrench,
866-989-7057,
Jpayne@MedWrench.com
Wed Feb 22 2017Reply from Darin
Empty the vaporizer and then run 100% O2 through it to dry the internal wicks thoroughly. Typically takes approx. 45 minutes to run it 1.5 hours to be safe and I would suggest a flow of 3-4 liters per minute.
Then I would fill with sevo and test outputs of the vap with a gas analyzer.
I would also question the tech as to why and how they did this........there are safety measures in place to avoid this from happening. Just my thoughts.
