I need help for oec 9600 mcachin, the machine doent finsh booting and no error massage is displaied, no kv, ma and floor mode is also displaied. All keys on the control pannel are not working, please help me with this regard
Sat Mar 11 2017
OEC machine
Wed Mar 15 2017Reply from MedWrench MM
If you are in need of immediate assistance please feel free to reach out directly to our Mobile C-Arm sponsors. They are happy to help out when they can.
Just be sure to tell them you were referred by Jonathan at MedWrench.
Jonathan F. Payne,
Media Manager @ MedWrench,
866-989-7057,
Jpayne@MedWrench.com
Thu Mar 16 2017Reply from Cbet_Matt
If it does not get past the >>>>>>> Check your 5VDC in the c-arm base. I think it's the second board from the left depending on your version. That's one issue I had with that booting issue. It's adjustable put it too 5.10VDC. If it's below 4.8VDC and will not go higher you may need to replace the board.
good luck. It's been years since I had that problem and a 9600
Matt
