Hi. We have had several problems where the centrifuge displays the error 'rotor?' and the lid locks. After a while, it opens but doesn't spin. After changing settings it resumes normal workload, but do you know if incorrect settings would be the only cause of this error message, or is there potentially another fault with the centrifuge that could cause this? We have one sent away with the same problem and they want to replace the motherboard, but I am checking.
Wed Apr 25 2012
Rotor? error
Tue May 01 2012Reply from GaryBiomed
You can try contacting Ozark
http://www.ozarkbiomedical.com/cgi-bin/commerce.cgi?display=contact
chris@ozarkbiomedical.com / 800-457-7576
