Sun Mar 26 2017
Error 5
This question is about a LabNet Vortemp56 Temperature Chamber Shaker. I am getting an Error 5 (Err5) after 3 seconds from a Start. The User manual states that this error usually appear when the user open the lid while the unit is running, making a temperature distortion, hence the operation error 5. None of that is the actual case. The error appear just after starting a session. The lid stay close. I suspected the Lid Switch or a sensor broken. It is not the case. If anyone happen to have a service manual for this apparatus it would be greatly appreciated if you could upload it. Cheers
   RE: Incubator, Laboratory Report Post
Wed Mar 29 2017Reply from MedWrench MM
MedWrench MM
I think your question may be better suited for our sister website, LabWrench.
Jonathan F. Payne,
Media Manager @ MedWrench,
866-989-7057,
Jpayne@MedWrench.com
Mon Apr 03 2017Reply from FredCailloux
Absolutely right !  Thanks for the advise, I will do so.
Mon Apr 03 2017Reply from MedWrench MM
MedWrench MM
You are most welcome, Fred.
Jonathan F. Payne,
866-989-7057,
