Thu Apr 26 2012
Code message "Machine Fault 809"
Recieving a code message "machine fault 809". I cannot figure out what is wrong. Help!
   RE: Ventilator Report Post
Sun Apr 29 2012Reply from MarkM
Where are you at, in solving this problem?
Have you already examined the system...or did a customer call this question in?
The 809 fault refers to a battery voltage level problem...So...the obvious questions to start are:
Have you tried replacing the battery?
Was the unit properly charged? Was it kept plugged in?
If it is not such a simple problem....then you will have to examine the
Battery charging and testing circuit
Mon Aug 02 2021Reply from raycobiomed
you have to replace the 9 volt battery in the back
