Wed Jun 14 2017
Error code
What is error code 1014
Fri Aug 16 2019Reply from DustinDuff
1014
POST timer/24V failure: system has
reset 3 times within the first 30
seconds of operation. Once this code
occurs, it recurs at every power up or
reset until the ventilator enters
diagnostic mode.
Review the diagnostic log: the code in
memory before or after the 1014
occurrence indicates the root cause.
If this code is not 4, 7xxx, or 8001:
1. Replace power supply.
2. Replace main PCB.
3. Replace CPU PCB.
4. Replace BMC PCB
