receiving error HUB 2800, states communication error, I can unplug, error goes away but returns about 20 minutes late while injector is just sitting there not being used. Suggestions??
Fri Jun 23 2017
Error 2800 "HUB"
Fri Jun 23 2017Reply from Crash
Inside the base is a network hub used for subsytem communications. You could have a loose connection or a bad hub. Newer injectors or Certegra Workstation systems will have a switch instead of a hub. Reseat all connections. If that does not work, you may need to replace the hub/switch.
Fri Jun 23 2017Reply from Ryan C.
I agree with the preivous about the hub inside the poewr box. If you have a second system, you could swap the poewr boxes between the two units to confirm. From there, I would chekc cabling and consider replacement of the hub.
RF Clarke
Injector Support and Service
888-667-1062
Ryan Clarke - ISS | We Are ISS | 888-667-1062
