Midmark 75 Evolution
RE: Power Report Post
The mIneral oil base that come with the replacement pump. The pistons were all working, but everything stopped. I can hear the solenoids engaging, but nothing happening. All the electrical connections are tight and receiving electricity when solenoids are engaged. Again, everything worked for five minutes after the pump replacement. I thought I had the problem solved, till the oil bubbled over and everything quit, again.
Possible relief valves or cylinder check valves not holding, anit cavitate valve. Sounds like a valve or multiple valves/check valves could be failing allowing all the oil to be returned all at once instead of regulated as normally and the pum can't keep up with it. Each cylinder has an electric shuttle valve, these could be sticking open. Are all cylinders extended when this happens? What if you just moved one cylinder at a time and see what holds and what doesn't? And you're positive nothing i hooked up backwards?
sounds like your reservoir is overfilled. the cap is designed to "spill out" fluid if there's too much
