Hello everyone. Can anyone help with the following fault i have on the AMX 700. The machine will only drive at half speed!!!!
I have checked the park sensor its fine. Ive changed the drive amplifier and drive control with no success. I've traced the 24v output you get when the tube is in the park position and that appears to be fine. Ive also tried calibrating the drive handle. Thanks
Fri Jul 21 2017
Half Speed Fault
Fri Jul 21 2017Reply from jimsdavis
see if it will let you make an exposure while tube is parked. if so, then the park switch is not working.you also may want to check the drive motor brushes on each side
