Fri Aug 04 2017
Need to solve the problem
The problem is the unit ready symbol does not appear after pressing the button. Assuming the button already check and ok no fuse blown in the control system.
RE: R/F Systems Report Post
Mon Aug 07 2017Reply from MedWrench MM
What equipment (make and model) are you specifically referring to?
Jonathan F. Payne,
Media Manager @ MedWrench,
866-989-7057,
Jpayne@MedWrench.com
Mon Aug 07 2017Reply from Larry Pines
Toshiba chest x ray model KXO 15 r/z1
Problem : No prepartion or ready no exposure. Rotor not working in x ray head
Try and try until you succeed.
Tue Aug 08 2017Reply from SHAH SHAH
Wed Aug 09 2017Reply from Larry Pines
I check the contactor its ok. I check with Volt ohm meter tester. I check the button switch its still ok. I check the x ray head the rotor not working
Wed Aug 09 2017Reply from SHAH SHAH
Tue Dec 22 2020Reply from Salman5625
I am having same problem. When i press ready button rotor turns on but light does not work and no exposure.. everything is working fine when kv is 102 and above. But lower than 100 kv its not working
