Printer Initiation Error
Hi Dave,
If you are in need of immediate assistance please feel free to reach out to our Vital Signs/Multi-Parameter sponsors. They may be able to help.
Southwestern Biomedical Electronics
Intregrity Biomedical Services
Jonathan F. Payne,
Media Manager @ MedWrench,
866-989-7057,
Jpayne@MedWrench.com
Assuming that this unit did not initially come with a printer/recorder installed, it’s possible the system default values were somehow changed to have the unit print based on certain parameters or alarm conditions. If that is the case, during boot up, the unit will try to initialize a printer. Not finding one would cause this error. If the unit came with a printer, the Default Default Configuration parameters may have been set for a printer as "present".
You may want to try restoring the Factory Default Configuration which is set by the manufacturer. These original Factory Default parameters can't be changed by the user, however; if a user changes settings to be different from the Factory Default values, the initial values can be restored from MONITOR SETUP menu. Directions there are self-explanatory. Barring that, a call to Mindray may be in order to diagnose a possible systems board problem. Hope this helps. Please let the group know what you find out. Regards. - Cipher
