Self test error
I have the same issues with the Aisys units.
Solution was to change the condensor with a new "dry" unit, stand the removed one topside down, so it drains and drys out. Water condenses and gets trapped in the convoluted tubing.
KK
We had the same leak problem. We have removed the condenser and put the cap on the machine. This stopped the leak issue. We kept some of the good condensers to use if needed.
We have had a few leak problems with the condensers. On one occasion they had bumped the condenser and the back side of the reservoir had moved outside of its seal. Another time there was a small piece of soda sorb between the drain plug seal and the reservoir wall. Couldn’t they make that seal a contrasting color to make this problem more obvious? I haven’t seen this yet but I hear that the mess of vertical tubes has a propensity to leak.
I see more leak problems, both breathing system & low pressure leaks caused by the EZ change module. I have had machines pass the system and circuit test (30 cmH2O) and fail the low pressure leak test (60cmH2O). The valve housing assembly was not completely seated or the O-rings were causing the leak. I guess we should consider this one of those job security designs and be thankful, but somehow it is just aggravating.
