Hallo, i have e problem about SSD 4000; when the equipment start compare on the Monitor display this error message:
"Power for ulrasound transmission was shut off as the system detected abnormal drive voltage.
Please reboot the system." If i don't connect any probe the display image is Ok, when i connect any probe a error message compare!
I make a Flash Rom update whit Foppy disk but nothing change.
Have you a suggestion, please.
Thank you.
Wed Sep 06 2017
Error message about Tx voltage
Sat Jul 17 2021Reply from azonnigbo
I have the same issue with my ssd-4000. How did you finally repair it? Thanks in advance
