Fri May 18 2012
Question
My GE MARQUETTE MAC 5000 only print to pushing RYTHM, but doesn't print to pushing ECG. Can you help me? Thnaks
Sat May 19 2012Reply from MarkM
Your problem might lie with a stuck key, the keyboard assembly, the acquisition module, or the CPU board.
Before getting into module-swapping, to isolate the problem...try using the built-in diagnostics tests:
The Keyboard test should reveal keyboard malfunctions and the acquisition module test should determine
whether the fault lies in this area. If there are any internal circuit problems...the power up system test should reveal them.
Envirionmental factors may also cause poor ecg performance.
