Fri Sep 22 2017
"Print Database Full, halting operation"
Or words to that effect.. this may be more a server configuration issue, but apparently the PIC Ix can print to the printer okay, but if a print request is made from a patient monitor, the above error happens. Any ideas? Suggestions?
Thanks!
RE: Patient Identification and Security System Report Post
Tue Sep 26 2017Reply from MedWrenchMia
Hello!
If you need immediate assistance, feel free to reach out to our sponsors. They would be more than happy to help!
Just be sure to let them know that MedWrench sent you.
Tue Sep 26 2017Reply from Shawnmolloy
When adding the Printer to your Surv. Central Station check your procedure. There are a couple ways you can add it and Philips had to correct us for a similar issue.
This is how we do it know. At the Surv. Central enter admin mode: supportuser. Go to control panel and add printer>choose the printer is not listed>Add Printer using a TCP/IP Address>Change auto detect to TCP/IP Enter IP Address of Printer and auto detect driver.
Philips said loading any other way could cause issues.
