turn on
Hi there!
MedWrench is available to help people with specific questions and troubleshooting problems. Could you please be more specific with the issue that you are having with your instrument , and the MedWrench team will do their best to assist you in solving the issue. This will also help other community members who face similar challenges.
Hello
the problem is that when I turn on my SIUI-5000 ultrasound scanner at the last stage of the ignition a message appears
title: CTS-5000: SIUI.exe application error.
msg:
the instruction at "0x00000000" referenced memory at "0x00000000" .the memory could be "read" click ok to terminate the program
Hi,
msg:
the instruction at "0x00000000" referenced memory at "0x00000000" .the memory could be "read" click ok to terminate the program"
I found a solution for this problem.
