My optmus 50 does not expose. when i expose the control panal does not display any error message. can any one help me by sending service manual.
Thnx
Irshad
Thnx
Irshad
I am having exactly the same problem, I hear the high speed rotor during prep and then pressing shoot, nothing. No error response. The ready light and high voltage indicators are showing green on the optimus console.
When you press test on the overhead does it give a message?
I will check that tomorrow. I also will be looking close at the limit switch for the cartridge since exposure will take place for above table exposures, I recently discovered. Thank you.
it seems rotor controller is defective. But firstly you must take error logs from optimus generator. OR you can check u-v-w check points behind of optimus. it must be about 10 ohms.
FIRSTLY you must take error logs.
Thank you for all the replies and good ideas. I have found that the limit switch for the cartridge in both the table and vertical Bucky is bad. I've repaired the Switches and all is fine. Thanks again.
i have the same but i can`t get error log cause i don`t have the service soft , can anyone help please
