Thu Oct 12 2017
PM procedure
Masimo EMMA capnograph PM procedure?
Fri Oct 13 2017Reply from Cipher
Lester Embry
Per Masimo, EMMA does not require a routine calibration/PM, however; Masimo states that the unit readings should be verified with a reference unit at regular intervals. Their literature suggests every 500hrs of use or anytime reading are suspect. I'm sending some documents to the MedWrench Admin for posting when contain the steps in performing the check. - Cipher
Lester Embry
Should have mentioned that a gas span check can be performed once per year.  - CIpher
