Preventative maintenance should be performed at a minimum of annually. A preventative maintenance program should
be established for all Stryker Medical equipment. Preventative maintenance may need to be performed more frequently
based on the usage level of the product.
CHECKLIST
_____ All fasteners secure
_____ Siderails move and latch properly
_____ All casters lock with brake pedal engaged
_____ All casters secure and swivel properly
_____ Inspect each caster and remove any wax or debris which may have collected on the caster or braking
mechanism
_____ Steer function working properly
_____ Fowler operates and latches properly
_____ Gatch operating properly (Optional equipment)
_____ Trendelenburg/reverse Trendelenburg operates properly
_____ Ground chain intact
_____ No leaks at hydraulic connections
_____ Hydraulic jacks holding properly
_____ Hydraulic oil level sufficient
_____ Lubricate where required
_____ Body restraints working properly
_____ I.V. pole intact and operates properly
_____ Oxygen bottle holder intact and operates properly
_____ No rips or cracks in mattress cover
_____ Accessories and mounting hardware in good condition and working properly
_____ No excessive play in the drive handles
_____ Press the handle switches - unit should not move unless the handles are pushed forward or pulled back
_____ Press the handle switches - move the handles forward and back and verify the unit responds properly
_____ Confirm battery powered functionality
_____ No cables worn, pinched or frayed
_____ Power cord and plug are free of damage
_____ All electrical connections tight
_____ All grounds secure to the frame
_____ Ground impedance not more than 200 m© (milliohms) max: Test point(s) include electronics enclosure and
motor chassis mounted to base of unit
_____ Current leakage not more than 300 ¼A (microamps) (per UL 60601-1)
_____ Batteries sufficiently charged (Optional scale system)
_____ Display housing intact and not damaged (Optional scale system)
_____ Load cells intact and not damaged (Optional scale system)
_____ Scale calibrated properly. Recalibrate, if necessary (Optional scale system)
