unit will not cut suggestions?
Mon Oct 23 2017
wont cut
Mon Oct 23 2017Reply from Ray Brown, CBET
Any signs that the Force 2 is malfunctioning? Did it pass the self-test okay, with no errors? Then, does the REM circuit pass? And then, are you using a single cable in monopolar mode and a foot pedal, or a disposable handpiece with both cut and coag? Does the coag work but not the cut?
Tue Apr 24 2018Reply from wraclin
