Wed May 30 2012
how to acquire standard DICOM dynamic 2D images
iE33 archiving as RGB still frames
How can I adjust the settings to acquire standard DICOM dynamic 2D images to a CD
The images are currently saved as all still frames
Thank you
Thu May 31 2012Reply from Kyle_Summit
Kyle_Summit
Hey Jp524
To change over to DICOM export you'll need to go into your setups menu then print/Network down the third box titled "Image Export " you'll see a drop down menu , open it with the arrow on the right and select DICOM for your image export setting, a reboot may be required.
Once you've done that you will be able to burn DICOM images to CD.
If you have any more questions feel free to call our Team 24/7 at 1-866-586-3744
kyle@mysummitimaging.com
Manager of Global Education & Training
Website: http://www.mysummitimaging.com/
Phone:  1-866-586-3744
24/7
Fri Jun 01 2012Reply from jo514
jo514
Thank you, and will this ensure a site is capturing the 2D images in a dynamic format? The images on the CD are still frame 2D and color.
Many Thanks, if this works you have made a monumental task breakthough for these folks
