Is anybody had this error ?
Thu Nov 02 2017
Error 05
Thu Jan 04 2018Reply from engzainab
It says in the manual:
Charge the device
If failure continues, switch off and do not use
Thu May 16 2019Reply from Sasha1d
Tue Mar 31 2020Reply from Chris-CBET
this error points to the battery not charging, not holding charge or the battery pcb failing to sense the battery voltage.
I had this last week, checked the battery 2.5vdc(2.4vdc is desired), placed it intot he charging cradle and updated the date, for 30+ minutes, no change. so it's the battery pcb.
Wed Oct 14 2020Reply from Medina Gentry
