RUT 9800 9900 OEC
Hello Steve and good luck in your quest.
We at Rad Rays do not sell or distribute proprietary software.
My suggestion to you is to buy a legal copy from GE.
However, if you need Technical Support or Parts you can rely on us.
Thanks,
Pat
The software is called 'Utility Suite'.
Access is via LAN cable or serial 9 pin 'D' type depending upon system version.
If you have a LAN socket you will have to program the IP when Utility Suite starts (must be on same subnet), it's not easy to explain all the tips to start accessing other than to say you must select the correct equipment type (Utility Suite), open then save FROM Workstation and/or Generator to file "backup".
Tom
