I would like to ask you the procedure to obtain 3d/4d images? Which is the sequence to do 3d/4d ultrasound? Thank you
Thu Nov 16 2017
VOLUSON 730 PRO
Fri Nov 17 2017Reply from MedWrenchMia
If you need immediate assistance you can reah out to our sponsors! They are more than happy to help:
Fri Nov 17 2017Reply from Mike Davis
In order to perform 3D/4D you first have to insure that the system you are using has the option activated. Then you will need to have a 3D probe.
From there you will need to do is press the 3D/4D button on the control panel.
Most systems will then give you the option to start the 3D/4D imaging.
Once you have the image you want press the freeze button and then save the image.
Michael Davis
Technical Support Specialist
Conquest Imaging
