Horizontal Arm
It's probably a bad brake cable. They like to break near the grommet where they enter the horz arm, on the inside. I've had to replace several.
@Maggie: No, I haven't tried that yet. Considering my next response, that may be the way to go.
@Ty: Brake cable is good, as brake does release. But, this unit had been running with a broken brake cable for a while when I first started working at this site in 2014.
@ old x-ray guy: Park latch does release and the brake releases, but the initial effort to get it moving is still too much. Considering all I posted here, I'll probably try replacing the brake itself.
Well, I disassembled the column assembly. In the bearing tracks are a groove, across the surface at about where the bearing would sit if parked. I suspect that this groove is what is putting up the initial resistance. Has anyone else noticed this? This is my first time tearing into one of these arms, so I don't know if that groove was intended to be there.
