For everyone out there with an AMX-4+ with Virtual Imaging/Cannon digital up-grade and are having Generator errors (45C) and battery issues. The first and usually only thing I do is sync the batteries using the Loop Test. Go into diagnostics and then Loop Test, write 0cb4 to address FF. This will cause bar graph and batteries to sync. Exit Diag and cycle key switch. When you turn back on the screen will blank after start up for 5 seconds. When it comes back on the bar graph and batteries will be synced. Most of the time this will fix any/all errors. Try it, it works.
Tue Nov 28 2017
