Customer reports every now and then there is water in the chamber at the end of cycle. I have checked the drain valve operation and it is working properly. The water fill valves are not leaking by. I have sat and watched this unit run over and over and of course will not do it when I am onsite. I am thinking about rebuilding the drain valve and see what happens. Any other ideas out there?
Tue Dec 05 2017
water in chamber
Fri Dec 08 2017Reply from Priebe
does the unit have a water cool down valve to cool water when draining could be slow leak and when machine is of for extended period it will be seen in chamber.
Mon Dec 11 2017Reply from Kara Crissman
Dear Jeff_EBS,
We came across your post about the Reliance 444 Washer. We have a dedicated Service Support team who can help. Please provide us with your preferred method of contact or call 1-800-333-8828 for assistance.
Sincerely,
Kara Crissman
STERIS Corporation
Tue Nov 05 2024Reply from Chris-CBET
