not booting
Which product (make/model) are you referring to?
good morning TEAM of MedWrenchMia
can you help me for IDC VGA SOCKET ON CPU BOARD pin out wiring
Aloka prosound ssd 3500sx mather board is EP525601CE
Thanks
Best regards
Hi,
1. Pls check battery Cmos --> Good or Not Good.
2. Have check HDD bad sector ? or broken?
3. Can you connect VGA cable with VGA port on CPU board?
Pls reply after checked.
Best regards
Dear Dangngoc, I had quite the same problem but my system doesn't show anything at all. The system is powered and all LEDs are light up except the HDD LED (I have been tested HDD with PC was working fine). Could you advice what could be the problem and How can I connect the external monitor with the IDC 10 connector ports?
Thanks
Phanna
